Thanks Shaun but I did not get the last word meaning? iid?Should be after the llh
I hope there’s additional expansion tank / tanks ?
Discuss Central heating not circulating after New Navien Combi fitted to Santon Premier system. in the Central Heating Forum area at PlumbersForums.net
Sounds like you need to separate the system. Also is the old boiler a non condenser @ShaunCorbs and the rads possibly ∆T 60?
No, the old boiler was a 20 year old Ideal Concord CX40 floor standing unvented.Sounds like you need to separate the system. Also is the old boiler a non condenser @ShaunCorbs and the rads possibly ∆T 60?
Yep
Low loss header
Then if the old boiler was running at ∆T 11°c the pump would of been capable of the higher flow rate and pressure required to overcome index circuit.
Sounds like this needs a low loss header and suitably sized secondary pump. The secondary side pipework will be ok in size but the new boiler internal pump isn't capable.
Alarming really as the installer really should have considered this
I agree. The boiler developed a leak from the heat exchanger seal 9 weeks in and charged 200 quid to do a 35Then if the old boiler was running at ∆T 11°c the pump would of been capable of the higher flow rate and pressure required to overcome index circuit.
minute job under guarantee. Now they do not want to know.
Reply to Central heating not circulating after New Navien Combi fitted to Santon Premier system. in the Central Heating Forum area at PlumbersForums.net
