Discuss Central heating not circulating after New Navien Combi fitted to Santon Premier system. in the Central Heating Forum area at PlumbersForums.net
I enjoy a pint at my local pub/restaurant owned by a hardworking Chinese family. I have had many years experience on property maintenance and they asked for my help.
He had an old LPG gas boiler feeding a Santon Premier unvented cylinder feeding 23 radiators and hot water for the kitchen. New boiler is a Navien combi and the pipework is a work of art!
The installers came out again and said boiler works as it should so problems is not of their making.
The upstairs living accommodation has a separate combi system.
When the fitters arrived he was given an option to retain the unvented cylinder, so he did.
The central heating no longer circulates around the building and about six radiators get warm.
I have bled and done everything to get it going but no improvement. It worked fine before the boiler change. The system was not drained. It was flushed four years ago. All TG's are working fine.
I notice that the original central heating Granfoss pump sucks the flow downwards to the cold feed of the cylinder at the bottom as a secondary feed. I found that the water temperature between 2 feet from the pump to the cylinder went from warm to cool indicating lack of flow?
I cracked open the drain cock and the temp from the pump to the cold supply into the cylinder is now even.
The expansion vessel is at 3 bar pressure.
I changed the pump to a nearly new pump which is working as it should. Still no improvement.
The problem is either; the installation of the new combi boiler? The routing of pipework not being correct? Or me not seeing the obvious?
Your help appreciated please. They are really nice people and I might get a couple of freebie beers.
Pictures?
Confused,
The system worked before the new boiler was fitted I assume.
Someone has fitted a replacement and now the system doesn't work and it's not of their making.
A couple of things,
To be able to say it's not of their making they'd need to know exactly what the issue is, so should be offering to fix it even if it means charging more than originally quoted.
They're the best positioned to fix it, they know how the old boiler was piped and how they've piped in the new boiler.
But they clearly don't know what the issue is, otherwise they'd have said as defence of why it wasn't of their making.
It would be the same as driving a car to a garage for a new engine, the garage fitting it and it starts but the car won't drive and the garage saying take it away the problem is not of their making.
My guess is that they maybe good boiler fitters, or even excellent, but have no understanding of heating systems and faults.
System worked fine with the old LPG boiler, now does not since they adapted the new combi boiler to
work with the Santon Cylinder. It was the customers decision to retain the cylinder and now the heating
will not circulate. The boiler is producing heated water OK.
I agree with you regarding the installers.
My Chinese friend has a pub and restaurant for past five years. They work hard and the UK is their future home.
The old Ideal Concord LPG boiler was knackered. They needed a quick solution so found an installer who could provide
a solution within days.
The Ideal Concord system was working well before the boiler expired. It was servicing the kitchen domestic outlets and four toilet
hand basins plus 23 radiators at various levels. The system is mainly 15mm to the rads and a lot of 22mm in the loft
and supply flow.
They installed a Navien 40kw domestic boiler in a commercial kitchen. They were assured that it would do the job.
The customer was most aware that if the Combi boiler failed to operate; the Concord cylinder storage with immersion was a back up and
would be a good idea.
New boiler is now installed. The central heating is not working. The first few rads will heat. If we balance the system we can get warm rads.
We asked the installers to come and solve the problem and the boiler was leaking water from the casing. They did attend very quickly and replaced
a seal on the cold supply to the heat exchanger. They charged £200 under guarantee for 35 minutes work.
We now have a system which provides good domestic output but no radiator heating to most of the area where it worked well before the boiler
change.
The installer says the 23 TRV's need to be changed at an extra cost of £1300 to solve the problem.
Do you know the old size of the concord eg kw and the new one ?
So probably 60kw
If Shauns guess is correct and the original boiler output was around 60kw, then a new boiler with a maximum output of 40kw is not man enough.
New posts
Reply to Central heating not circulating after New Navien Combi fitted to Santon Premier system. in the Central Heating Forum area at PlumbersForums.net
losing pressure
L
T
Hi We urgently need to get our h/w cylinder replaced because it's leaking. Our current system is oil boiler feeding underfloor downstairs...
Have a sytem boiler with unvented cylinder with 2 heating zones plus hot water in a house we moved into recently. To start with we were always...
M
Hi, we have a back combi heater. Whenever the heating comes on it seems to lose pressure within a few hours and I have to refill each morning...
Hi, I drained the the central heating, to remove a radiator. After refilling it, the heating now won’t work. It’s a combi . I’m getting this symbol
