John Flower
- Messages
- 33
Micro bore is fine on sealed systems which have been cleaned and dosed with the correct inhibitor. To do the job properly you need to size the pipework to suit the size of the rad. Too many times have i been to jobs where there has been multiple rads on 15mm or 10mm and the system takes ages to warm ect. If you are replacing rads or fitting a new system then it pays to design the flow rates /pipe /rad sizes correctly as it cuts out any call backs at a later date. Typically the client will always say that the system worked fine before you came. So it pays to check over the system to note any design faults and point these out before you start.
