Discuss Central Heating circulation issue in the Central Heating Forum area at PlumbersForums.net
Hello i recently converted heating system from old stove to grand vortex b house 90 , boiler runs and works fine . How ever i have issue with water circulation have installed new pump but for some reason water don't circulate at all . what are the possible cause ? i have pump installed on return and and have one way valve on coil return I have attached image on how it looks like and schematics
Pump installed in the wrong place also shouldn’t be facing up the bleed screw needs to be on the side or at worst 45 degrees
After the cylinder but your feed and vent arnt in the best position most likely will pump over
As per my image also best to upgrade to an s plan from a gravity set up also while your at it eg port valves
So in the picture the right are the pipes straight from the boiler ?
New posts
Reply to Central Heating circulation issue in the Central Heating Forum area at PlumbersForums.net
I am sizing the central heating pipes for a complete replacement. The property has an elongated floor plan so I have used a piping layout...
Hello, I live in a two floor semi with a gravity fed conventional gas fired boiler (Potterton Kingfisher MF). The boiler is fed cold water from...
Hi, Over the past few months, my wife and I have noticed a constant pulsing sound throughout the house which is particularly noisy at night (this...
Can central heating / gas engineer expert help me with below issue. During winter time only, I have been having issue with low pressure or...
