H
HelpThisDude
Hello All, first post here and I really hope you can help me.
I’m no stranger to tools and meters, but I have no idea about household plumbing or CH systems.
The Problem:
Yesterday we had a strange vibrations running through the house, sounded like drilling. It was coming from the Airing cupboard. The pump installed for boost the bath/shower smelt and was causing the noise. No one was using the bath at the time.
The installers said that the motor on the pump had burnt out, because the water was too hot (max on pump was 65DegC). They will replace the pump, but want us to fix the water temp problem.
They blame the rectangular shape stat strapped to the side of the immersion heater/tank, (the electric part never used) made by Danfos. He explains that this is not regulating the temp of the tank.
Does what the bathroom shop guy said, make sense?
I have used a RS Thermometer to check the temp of the water (at the tap), and it is at 63.9 DegC. The stat is set to 55 DegC.
I have since turned it down to 45 DegC on the stat (let it for the night), and the temp of the water in the morning at the tap is reading 61.2 Deg C
When the dial on this stat is turned it does click in, and out. I have no idea of the best way to test it, or if a different component is faulty?
The Problem:
