Discuss cavitation??? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
gasfit247
Hi I wonder if any one can help me please. My ch heating is an open vent yplan when I have the heating on the pump is quiet but when ive hot water only its very noisy . Is this cavitation ? & if so how do I cure . There is no bypass valve at the moment would this help? Any help gratefully received simon
Very much doubt a BPV would do much, when did this start and have you had any recent work done, any pics? describe the noise?
hi there I fitted a new boiler pump & dv in april ive had no problems till now
No I don't think so, the pump is making a knocking noise also when I first turn on the hot water I can hear the water circulating quite loudly .
Is there a balancing valve fitted to the flow or return on the cylinder?
if there is check its open enough to allow a decent flow, or maybe theres some crud in the valve restricting it slightly.
Hello I don't think so, but there is what looks like an automatic air bottle on the flow ta the cylinder this does look seized up .. but I don't think its a check valve is it???
soumds like air in system, had the same on a duo tec this pm, having drained down to fit an expansion vessel below boiler, no fretting, the cupboard was fitted round the boiler such that i couldnt get the side mounted boiler expansion vessel out!!!!!!!!!!!!!!!!!. I thought the impellor had fallen off the pump until I managed to bleed all the air out, thankyou to all those who insist on shuttting AAvs!!!
Reply to cavitation??? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have just had my central heating system "upgraded" for a four bed-roomed detached house. The heating company recommended going from the open...
1K
Hello, I've just found this forum and wondering if anyone can please help us. We've not long moved into our new home. It's has Johnson and Starley...
Hi All, Hope somebody can help :) I have a vented HW system with a pressurised Ch system but got bit of a annoying issue, when the hot water...
C
Hello I have a gravity fed system with a header tank in the loft, a water cylinder and a 3 way valve. The header tank in the loft is OK and has...
Heating and hot water is not working. Plenty of heating oil. I have replaced batteries in thermostat and it seems to be working ok, showing flame...
