Discuss Cast Iron Bath renovation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
V
veebee
I have had my cast iron bath re-enamelled and hav purchased new taps for it....but, the tap holes are larger than the base of the taps. Is there a skirt or collar that I can buy to cover the tap hole? if so where from? :confused:
So the tap can fit through the hole then, or the base of it ? Have you tried buying taps that do fit? would be better in the long run .
Hey dude you should have noted the size of taps before u could buy it, I dont think u can fix it with the help of a collar , the only way is to replace it with the correct dimension one.
Reply to Cast Iron Bath renovation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a plumber coming tomorrow to change a cartridge on a badly dripping tap on my bathroom mixer unit. There is no separate isolating valve for...
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes...
I have attached an image of the brass body within a tap. Having replaced a cartridge which has cured a leaking tap, I can see that there is a...
