Discuss cast iron again in the Plumbing Jobs | The Job-board area at PlumbersForums.net
pauls
dont know how i keep getting them:(:D
i take it i can strap boss into cast iron stack and cutting into it is with a normal hole saw and carefuly does it
Yes with a decent holesaw and some patience you will be able to drill ithe stack getting a decent seal is another thing tho.... scraping the paint off and a light smear of clear silicon usually does the job .
further to the cast iron stack there is a branch on it with a cap on it, i want to run a soil pipe into it any tips on getting the caps off
My preferred means of making a hole in a cast iron stack is with a Rotabroach fitted with a magnetic clamp.
What sort of cap?
Hemp and paste is far better for sealing onto cast iron than silicone.
if its caulked lead youll need a good sized blowlamp to melt the lead out takes a while just keep heating and digging the lead out with a screw driver til its all out and the yarn will start to burn then tap it of
youll go home smelling like a bombfire mmm i can smell it now
it may have been cemented on if it was capped later in which case its a hammer small chisel,drill or whatever to break it out
unusualy to be caped as branches were normally socket ended in which case its a plug
What sort of cap?
not sure i just looked up and noticed a cap over the branch and thought thats where i should be able to to run the soil into
ideal opportunity to quote for a new stack, first thing we do if theres a cast stack is advise a new stack extra work and all that.
unless its an old building they want to keep it
Reply to cast iron again in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down...
