Discuss Career development route after CG 2/NVQ 2 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A1P
hi,I came into plumbing after some 'work experience ' which I enjoyed.I was in my twenties and wanted a career.After research,I managed to avoid the expensive courses that led nowhere-no opportunity to gain NVQ 2.I did this via the local tech.1 day per week.I had to go self -employed as this qualification is the minimum to seek employment and even then experience is lacking.I have applied knowledge gained and worked within my limitations.I have had some work with other plumbers.I have justed signed up for CG/NVQ 3 in plumbing 1 day a week which should widen and deepen my knowledge.I have done some work on central heating 'as far as the boiler'with a Gas Safe engineer.It is an area which interests me and will take me away from depending on full bathroom refurbs which are rewarding but increasingly difficult to come across.I was wondering if I can do ACS before completing my NVQ 3.If so,I appreciate I would have to work selectively or get an experienced plumber to mentor me.I understand gas is much more lethal than wet plumbing.Basically I am trying to develope my business the right way within the present system.
to get your acs quals you have to complete a portfolio of experience so keep in with your rgi to allow you to do this. if your doing your 6129/nvq3 at college then this should tie in ok so you do the acs part on completion of your tech cert etc. takes time but cheapest way of getting your tickets sorted out imho, and you have time to learn it properly.
Reply to Career development route after CG 2/NVQ 2 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Article
A Plumber Who Worked Illegally Gets A Suspended Sentence After Falsely Claiming To Be Gas Safe Registered. A Plumber in Herefordshire was prosecuted after Hereford Trading Standards Team found that he was falsely claiming to be on the Gas Safe Register when he was not, putting members of the...
