Discuss Capped strap on boss connector in the USA area at PlumbersForums.net
I need to fit a waste into my external soil stack and it already has two strap on boss connectors I could use. These have been somehow capped off and I would like to know if there is anyway I can use them to do my job?
Reply to Capped strap on boss connector in the USA area at PlumbersForums.net
Hi. I need a new toilet supply line but donā€™t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic nut about the same size as the one going into the cistern but has a different thread. Attached is a photo. Can you advise. Thanks.
Hello all, Iā€™m replacing a concrete paving slab patio in the back yard. The original patio used 50mm deep concrete slabs on hardcore & sand. Iā€™m planning to pour a 100mm deep concrete patio on 100mm hardcore. In order to achieve the same final height to line up with the rest of the patio, I...
