Discuss Can anyone recommend a decent water softener for an UVHWC? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Like the question. Need a water softener..was looking at Dualflo anyone got any recommendaions? Also an in line water filter.
Obviously ones that can handle high pressures.
cheers
Scalemaster Softline 150 + Highflow kit
+1 (op) but if it was for that house you posted about i would choose the 450
I like monarch softners personally with 7 year warranty
Fitted my first one this week, seemed okay... There all pretty similar to install I find!
I prefer the tapworks ones when fitting with the highflow hoses as they come with preformed bits & built in check valve which allows the 22mm bypass assembly to be fitted more compactly! The monarch just tossed in 3 22 levers & separate check valve which takes up a lot more space!
Reply to Can anyone recommend a decent water softener for an UVHWC? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can anyone recommend a decent multi meter, preferably under a 100 pounds. It's for checking boiler components so I don't need a top spec one...
Hi, My current hot water system needs to be replaced. Anyone got any suggestions or can recommend any plumbers around Derrimut area that won't...
