Discuss Can a waste cap be unscrewed? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Can anyone advise - can this type of cap be unscrewed? (one end of a kitchen waste pipe) If so, is there a tool to unscrew or should it be able to be unscrewed by hand?
Similar to the following...
Yes, generally. Depending on how long it’s been in, it’ll probably needs some pressure from water pump pliers/grips to undo. Careful though, as it could break.
Thanks - it has been on there 20+ years... not sure if it is glued on or screwed... difficult access at back of sink unit... I wonder how it could break.... that would be more of a pain..
Reply to Can a waste cap be unscrewed? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Does anyone know where I can get one of these? Toilet is leaking into the bowl. This one pushes in with a half turn but I can't find one anywhere.
Our kitchen mixer tap has started dripping. Like so much of the plumbing in our almost new build bungalow, it is lacking! The plumber didn't...
