Discuss BTU calc help in the Central Heating Forum area at PlumbersForums.net
Alright chaps,
I’m a bit embarrassed to actually ask this but need some help with something relatively simple.
I need to figure out the Btu’s required for a large open planned room but it’s a bit different from a ‘normal’ room and I’m so used to using a app to calculate sizes and my minds going blank on how to do it properly
The room is a converted garage that has a couple of walls that are stone and block with 50mm insulation and two walls that’s are
The room will then have studding put round internally with 100mm cellotex in.
The room will be open vaulted with a approximate size of ; 5.5m wide, 8m long and 2.4m to wall plate heigh and approx another 3m from there.
I’m unsure whether to work out it as a rectangle and then calculate the upper area as a triangle and double it to work out as a squared area (if that make sense)
And then unsure of how to calculate/allow for the insulation as there sort of two walls/insulation
Sorry if I’m being thick but hopefully someone can help!
Worked it out approximately 2 outside walls etc
Its quite a time consuming and complicated task really and you need to know some data first if you're going to do by hand, although there are websites/software out there that do it for you but they also require the same data, however I would prefer to do by hand. There's two ways a room/building loses heat. 1. Ventilation heat loss and 2. Fabric heat loss. When calculating the ventilation heat loss you need to the total volume of the room, the air changes per hour for that type of room, the design outside temperature and room target temperature. Example.
3m x 4m x 2.4m = 28.8m3, now x that by air change rate, then x that by the design temperature difference and then x that by 0.33 to get your total ventilation heat loss in watts.
Fabric heat loss is a bit more complicated.
The calculation is. Surface area x temperature difference x U value = rate of heat loss in watts.
You would need to know the U value for all materials in the walls and that of windows doors etc.
Thank you.
Reply to BTU calc help in the Central Heating Forum area at PlumbersForums.net
