Discuss Broken pipe outside in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi folks,
I have this broken pipe outside and just wondered what the best way to fix it, I’m kinda assuming I have to put another pipe inside and seal it somehow, but not sure 😕
Thanks for any help, hope it isn’t too much of a big job.
You will need to trace that pipe inside the property where hopefully you will find a joint just the otherside of the wall and start from there to the outside.
Looks like Push-Fit connections so easy for you to work with, has it been painted black?
Hmmm just looked in the kitchen and seems like I would have to remove all the fitted kitchen unit just to try and trace the pipe, is there a temp fix I could do from the outside?
I don`t see how, there is nothing there to connect to. Isn`t there an elbow inside directing the pipe through the wall? Being push-fit they simply push together with a rubber seal to err, seal the joint. if you need to cut the pipe there is straight connector available.
Unfortunately it does have water coming out, seems like the dishwasher, only problem is that the house we moved into has a fitted kitchen so I can’t seem to get to the pipe with making a bit of a mess, but I think that might be our only option 😕
Reply to Broken pipe outside in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, My partner and I recently bought a house and have been attempting to make the bathroom less fugly. I was removing the bath and shower...
Hi, I've not posted for a while, not a plumber, but a keen DIYer who likes to try and do things without bodging if I can. Basically I'm wanting to...
60's ranch, with single bathroom. Tile over concrete slab. Toilet is about a foot from exterior brick wall. Vent pipe is in interior wall behind...
Hello guys, a couple of months back I installed a new shower and sink into a part of the house that hadn't previously been plumbed in. This forced...
[ASIDE: I did wonder if this was the best forum for this but figured as it was a boiler related issue that the gas engineers would be dealing...
