Discuss Broken jumper on bath tap in the DIY Plumbing Forum area at PlumbersForums.net
Hi, we have an old Howard bird mixer bath tap Edwardian brass style. The jumper on one tap first snapped and now has broken off completely. Can't replace tap as the landlord decided it was a good idea to completely tile the bath in when the bath got fitted about 50 years ago. Landlord is useless. The tap constantly leaks badly, the jumper does not come out to just replace the jumper. I have tried fitting two washers then a metal washer behind the rubber one for some stability and to act as a jumper but it still leaks. Can I buy a new internal part for the tap or would a domed washer be any better? Replacement of the whole tap fixture won't be possible as I can't get under the bath to unscrew the taps. I have attached a photo of the tap with snapped jumper before it broke off completely. Any help on how to repair this would be amazing. Thank you.
Replacement complete valves are available, you just need to match up the number of splines and length of spindle.
Just one site to look, search for tap spindles / inserts, check you are looking at washer type and not ceramic disc type.
Also check various sites as prices vary for the same items.
Reply to Broken jumper on bath tap in the DIY Plumbing Forum area at PlumbersForums.net
Hi all, My partner and I recently bought a house and have been attempting to make the bathroom less fugly. I was removing the bath and shower taps to replace, but while removing the bath spout (which had no nut to undo), the threaded section of the pipe broke. I thought the bit that broke must...
Hi, My Blanco Kitchen Tap Model Swift BM1420 is leaking. Please see attached photos for details of where water leaks from. What I've done so far. I replaced the cartridge. Leak persisted. Bought some replacement seals and tried to put in place of the old ones. Here's what I did next. Remove...
Hi. Can anyone help me get into this tap? I have them on the bathroom sink and bath and 2 out of 4 are dripping. I've have had two plumbers in to replace the washers and neither could get them open. The gold coloured ring under the top unscrews on two of them but won't budge on the ones that...
I need to replace the washer of my kitchen mixer tap as it is leaking. I was able to remove the spout once by unscrewing the screw on the back of the tap. However now I can't remove it again as it seems I must have used the wrong screw head and have rounded off the head. Please see attached...
C
Hello, I'm wondering if you can help me. I have an insurance company who is trying to get me to make my plumber re-quote for work to replace a broken bath. He's included a bath panel with the quote as it's the type of bath that requires a panel (and the original style is not available so can't...
