Discuss broken exterior pipe in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hello plumbers
Just noticed my boiler waste pipe has broken ! Do I need a plumber to fix this or can I do it myself? Advice much appreciated!
Should be doable yourself if you have some ladders
Overflow coupling, overflow elbow and some overflow pipe and glue
Sorry ...just one more thing. How do I connect it to the drain/ seal it?
Thank you Shaun
Looks like it was just pushed in
I would recommend fitting a hopper to the rain water pipe
Reply to broken exterior pipe in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
60's ranch, with single bathroom. Tile over concrete slab. Toilet is about a foot from exterior brick wall. Vent pipe is in interior wall behind...
Need some advice, neighbors sewer drain keeps blocking up every few months. My wife and I have always chipped in with the other three neighbors...
Hi everyone I hope you can help. We were getting some work done and our builder attached the boiler condensate pipe to the sink waste pipe. This...
Hello I have a condensate pipe that appears to be leaking at the joint. How do I fix the leak? Would something like plumbers putty around the...
Hi have surplus water feed and return pipes in my home. I can't isolate them so will need to freeze. House built 1970's. They're as far as can...
