Discuss Bosch washing machine cold fill in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Thanks for explaining the process, Chuck.Not really plumbing but it's pretty quiet here at the moment so I'll bite:
Based on my own machine, the number of top-up fills seems to depend on type/weight of clothes to be washed. The machine will initially fill to the set level, which is surprising low – only a couple of cm above the lowest point in the drum except on the 'delicate' cycles. It then churns the clothes a couple of times, which soaks up some of the water, and then does a short top-up fill to restore the level. It repeats this process until the clothes are saturated so no more water is needed.
Bosch WMs have quite a lot of diagnostics built in. If there is a problem with the water supply/pressure it will display an error code.
You can always call Bosch Customer Care:
Contact Bosch Customer Service | Bosch UK
If you require assistance with product advice, spare parts and accessories or you would like to leave some feedback, please contact us today.www.bosch-home.co.uk
if you suspect your machine isn't working correctly.
Reply to Bosch washing machine cold fill in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
