Discuss boiler will not communicate with reciever in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
M
mr bury
. ideal logic plus c30 , hot water fine boiler wont communicate with reciever honeywell stat sends signal reciever turns on ,will not fire boiler up
Assuming Y-plan or S-plan system, boiler receives switched live via the 3 or 2 port heating valve, not directly from the honeywell receiver. So the issue could be with a motorised valve being stuck, or the motor not operating microswitch in valve head.
Reply to boiler will not communicate with reciever in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
