Discuss Boiler types in the Plumbing Jobs | The Job-board area at PlumbersForums.net
P J F PLUMBING
Please don't call me thick !!! Got to change a ideal classic. It only runs the rads no cylinder just f/e now is that a regular or a system ?? 9 out of 10 boilers I fit are combos answers on a post card please !
If its on an f/e tank, then its a regular heat only. It only becomes a system boiler if it has the pressure vessel inside the boiler.
No copper tank or unvented just the boiler running the rads a regular how much for a 15 kW lpg one Ray lol
Dont have the lpg cost to hand pete, but I will get someone to look it up and call you tomorrow.
Do you have a preference for brand? Main is probably most cost effective (rebadged Solo) but I am not sure if they do it in LPG.
I'll call in the morning that ok. I need x8 water heaters and x2 heat only boilers in LPG all the flues ect I'll call to get cost ect mate
Mostly fit combis is but getting a lot of call for heat only lately
I always thought a system boiler had a pump in as well?
It usually does. But its the pressure vessel that makes it a system boiler - they always used to be called "sealed system" - we just dropped the word sealed.
Most manufacturers made their system boilers by taking a combi and stripping out the unnecessary DHW components, which is why the pump was usually included in the boiler. Once you get in that habit, there is an expectation that there will be a pump in a system boiler, so now even the ones designed from scratch tend to include one.
Ok tommorrow I'm doing a heat only but they want it converted to fully pump with 2 . Two prt valves. I've never done this before feel really out of my depth !! Any stupid guides ?? Help ect ??? Pictures guides please
It's easy buddy where is all your pipe work? What pipes you got at boiler and what u got in a/c ? Will draw u a picture if u babysit so I can. To pub
make sure its suitable to convert, ie has overheat stat already.
It's a grant job all been looked at and got the paperwork that says convert to fully pumped incorporating 2 port valves I haven't seen it I'm going there in the morning I don't want to look thick and say I don't no how to do it ?? The wireing getting done by a sparky but I have to change the boiler swap for swap and convert to s plan. Never done one before I usually fit combis Ahhhhhhh
Reply to Boiler types in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Firstly I won't be touching or going anything... I only want advice if this is right.. my partners dad has a aga that is solid fuel unregulated...
Evening all. I have an open vented C/H system with a heat only boiler and 10 rads over 3 floors. I checked the system mid summer and all was ok...
Hello friends - I really struggle to understand my heating and hot water system I posted my question on Diynot but it ended up being five pages...
Any advice welcome as plumber stumped Had 36-46 grant vortex utility boiler 7 years no problem recently oil tank move and tigerloop install...
I just had a quote for a new boiler install as follows I dont undertand why a 15-60 boiler pump is needed and a 25-100 pump is needed as well I...
