Discuss Boiler time clocks that... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
mutley racers
Subscribed
Just stop ticking. Do they just die and need replacing?
yes
Reply to Boiler time clocks that... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PSxxxxxx
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath the boiler is difficult with lots of obstacles, is it okay if I run soldered copper over / across the top of the boiler? It'll be about 4" off the top...
