Discuss Boiler pressuer in the Plumbing Jobs | The Job-board area at PlumbersForums.net
diantalvic
I have a combi 105HE boiler, when ever the heating comes on the pressure goes above 4 bar, any idea why it is doing this and how I can stop it? This started this morning.
(Also when the hot water is turned on i never actually get hot water, not sure if the 2 are related although the hot water issue has been going on for months)
hi you will need a gas safe engineer to attend your appliance.
i have someone coming out next week do you think it will be ok until then? i wont use the heating much until then just to be safe
It shouldn't be able to get to 4bar. Best to switch it off until it's looked at
No it wont mate , your better trying to get a quicker visit , the boiler safety valve should be emptying the pressure outside at 3bar so it should never have a 4 bar ,
ok ive switched the unit off altogether will get someone out as soon as possible. Thanks for the replies
Maybe faulty pressure gauge as well or prv is stuck ! but good idea not to use boiler.
Definitely turn off and get someone else sooner.
However, because you're unregistered and not a gsr.......
For you this thread is over.
Reply to Boiler pressuer in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My Grant combi oil boiler is giving me quite a headache at the moment. When I returned home last Friday I'd no heating or hot water. An engineer called the next day and diagnosed a faulty pressure switch. This was changed and everything seemed ok. However then the boiler began to lose pressure...
I have been facing central heating low pressure on unvented hot water RM Cylinders but can't see any leak on the PRV, expansion vessels and plasterboard celling. I have got unvented pressurized RM Cylinders hot water system with 27KW Worchester gas boiler with expansion vessels . When...
losing pressure
L
Can central heating / gas engineer expert help me with below issue. During winter time only, I have been having issue with low pressure or pressure dropping with unvented hot water cylinder system. During summer time there is no usage of central heating so the pressure at unvented system is not...
Hi, Over the past few months, my wife and I have noticed a constant pulsing sound throughout the house which is particularly noisy at night (this could be as a result of us noticing the sound more when there is less environmental noise). Unfortunately, it is severely disrupting our sleep, so we...
M
Hi, we have a back combi heater. Whenever the heating comes on it seems to lose pressure within a few hours and I have to refill each morning. The boiler seems to function well, and the pressure only drops with the heating and not the water being on. Ie it started last winter and was then...
