Discuss boiler only works when internal timer is removed & connected to nest in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all,
I have an ideal C24 boiler which is connected to a nest thermostat. The hot water works however the central heating does not work. I discovered when I removed the inbuilt timer connection to electronic board and turned heating on using nest the central heating works. Is this a faulty inbuilt timer or could it be something else. I am afraid of keeping it disconnected incase it deactivates any fail safes.
Closed needs a gas safe engy to wire it up properly
Reply to boiler only works when internal timer is removed & connected to nest in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
