Discuss Boiler not getting up to temperature (or is it) in the Central Heating Forum area at PlumbersForums.net
We have an old Ideal Elan 2 RS 50 boiler and without doubt it's be rock solid. Yes we will be replacing it in the new year, but for now it'll do. However, it does not run as hot as it use to (or so I think). Please find attached a graph of it's performance today. It is set to "High". So to confirm, is this typical or should the boiler be running hotter and is the going on and of also typical. Information on this would be very helpful.
Kind regards
Matt
1. It will shut off when the demand for heat is satisfied. I.e. when the heating is up to the temperature set by the room thermostat and / or the hot water reaches the temperature set on the cylinder thermostat. This may mean the water never reaches the maximum temperature set for the boiler itself.
2. I'm pretty sure your boiler is not of the modulating type. So it turns on, runs until the heating demand is satisfied, turns of. Rinse and repeat. More modern boilers adjust their outputs to match the demand rather than following this on-off cycle.
One would think that a non modulating boiler will or should always reach its boiler set point and then cycle on/off until the room stat or cylinder stat is satisfied, my oil fired boiler will run continuously for ~ 30 minutes in the mornings until it heats up the system contents and then cycle on/off, 65C/75C, until the room & cylinder stats are satisfied.
If your boiler temperature is set to maximum, the boiler is not operating properly - but you knew that. If you get it serviced and explain the problem, it is probably a straightforward fix.
Has the boiler temperature potentiometer bern adjusted over the time you recorded the trace? If not, can you explain the spike?
Reply to Boiler not getting up to temperature (or is it) in the Central Heating Forum area at PlumbersForums.net
WB 4000 installed a few months back, just balanced the 7 rads - managed to get around 15 degrees delta across most rads. Not quite the 20 degrees...
Hi, Am trying to understand my mother's Apollo boiler. It has an intermittent fault. In the last couple of years, it has had a new...
Hi looking for some advice here if anyone would be so kind. Our existing system consists of an Ideal Logic Heat H15 heat only boiler paired to a...
2K
N
Our ~15-year-old boiler just broke down (the spark igniter gave out), and set out a discussion to go ahead and replace it, as it's starting to...
I am generally a decent handyman, can usually make 2+2=4 and take care of most things to avoid troubling experts with just the basics, but know...
