Discuss Boiler locking out after expansion vessel change in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
thorn
This might be total coincidence, but I serviced a boiler (ferroli) a few weeks back and fitted an external exp vessel a few days later (the internal one was knackered and it was about 1/3rd the price to fit external). Got a call from the customer and he says that the boiler locks out every night and when it is on the rads are getting extra hot during the on periods. Could this be thermostat related or could the exp vessel be affecting it - don't really see how it would
thanks
I think someone is trying it on! Now way an expansion vessel will cause it to lock out. Or at least I've never come across anything like it.
What he said, Ive heard some real horror stories about condensing ferrolis.
It was ok until you touched it !! Its a ferroli what do they expect ?
Reply to Boiler locking out after expansion vessel change in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Hi, we have a back combi heater. Whenever the heating comes on it seems to lose pressure within a few hours and I have to refill each morning...
problem with my oil boiler everything has been change all cleaned out set up but still locks out , if I remove photcell and shine a light on it it...
2K
Hi. I have a firebird enviromax combi boiler. each time it turns off the motor on the riello burner keeps running for a while then the whole thing...
3K
Hi All, We have finally decided after a bit of a persuasion to have installed a utility room in our garage that currently houses our oil boiler...
Hi, I have had this problem for a week now. The oil boiler will run for a short while and then stop. If I check the pipes around the 3 way valve...
