Discuss boiler heat shields in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
crisk
Hi all (gas engineers)
Im a gas engineer, and am currently servicing numerous makes/models of boiler everyday. Some of the older types i come across with an accessible combustion chamber with main burner and heat shields (normally four surrounding) i clean off heat exchanger and brush burner and heat shields clear. obviously in a confined space i tend to breathe in this dust and have a sneezing fit and nose hurts after for a bit! This may be a stupid question but i can't seem to find out (only looked on internet so far!) what the heat shields r made of.....Is the dust harmful???? sorry if that makes me look dumb just haven't bothered to call manufacturers yet.......
Chris
Chris
Welcome to the forum crisk, old boilers can contain asbestos have a look at this link originally posted by mike jackson
[DLMURL]http://swbjackson.zenfolio.com/tb-140-applainces-known-to-contain-asbestos-materials.pdf[/DLMURL]
some of the boilers contain asbestos and there is a list available. I was cleaning a back boiler for a polish doctor years ago and there was a bit of black soot floating about in the air. She informed me that once black soot gets into your lungs it doesnt come out again. I now wear a mask and avoid back boilers
Hi Chris and :welcome: to the forum :)
I do my best to keep the vaccuum going if and when I brush down heatechangers etc! Thorn Apollo's use to leave a strange sweet taste even though I didn't lick them clean :) God Honest Truth :)
Do be careful of Asbestoss though!
I have gone off servicing and now just stick the FGA in the flue instead
You know what it is when they first brought the FGA out that is what we were lead to believe! Less than 0.004 leave well alone! Well with no boiler cases being removed you can imagine the issues that were building up and still are!
cheers all, I've just looked at the list and whoops!! I've done a few of them and breathed it all in! great!! i'll wear a mask from now on. if u hear of an engineer dropping dead in the south...that be me! And I've heard stories from customers that tell me some engineers come in for 5 mins do the FG Analyser test then bugger off, I've gone in 3 months after a BG engineer went in passed the boiler and issued an emissions certificate, i did the test the alarms went off on my analyser i opened the chamber and the heat shields were half rotten and the boiler casing was starting to go......so i now open every boiler casing, (which i did anyway) but u should always check that....no point cutting corners....
I am not interested in making work for myself but always ask the customer what they want as most usually want a safety check or GLSC. My mate has pulled BG up twice where they have passed 2 boilers both had the flues rotted on them. BG were very quick to replace both boilers or get reported
Im the same, breathed in so much stuf before, went to the doctors about it because i seem to always be short of breath, im actuly worried ive breathed in asbestos. Brought a mask since but always forget to wear it.
Reply to boiler heat shields in the Plumbing Jobs | The Job-board area at PlumbersForums.net
