Changed some radiators in a customers property. The property is a bungalow with all the pipes under the floor (mainly concrete). It looks like 2 circuits one with 2 radiators and the other with 9 radiators. It refillled okay but when I put the boiler back on I couldn't get most of the radiators to heat up. The circuit with 2 radiators was fine but the other circuit only what appears to be the first radiator heats up, if i switch off all radaitors and turn one on at a time only what appears to be radiators 2 and 3 get very luke warm 4nto o9 stay cold. I attached a hose to the radiator that appeared to be the last in the series and got good hot water flow but when the radiator put back to normal it does not heat up. It looks like a blockage on the return somewhere between radiators 1 and 2. This part of the system is much older than the rest which I think has been added to when extension work was done.
What I plan to do is attach a hose to the vent on the second radiator, close all radiators and open the flow to this radiator to check flow okay. If okay close the flow and open the return and then open the flow and return on the first radiator. If the return between the first and second radiator is blocked then the nothing will come out of the second radiator vent, if it is not blocked then some water should come out of this vent. If no water comes out of this vent then I am going attatch a hose between the vents on the first and second radiator, close the flows on these and open the returns, open flow and return on third radiator. My theory is that if the blockadge is between 1 and 2 then the flow will go through rad 3 and then into the return of rad 2 through the pipe to the 1st rad and then out through it's return. If this is successful then I will try and flush mains water through the return pipe between 1 and 2, no problem flushing in return direction but if I try the other direction I will have to block off the vent and cold feed. If this does not work then I will have to get somebody with power flush equipment to try and clear it as I do not have a power flusher.
Should all my investigations prove that there is a blockage then I think the only option is to run a surface pipe from the return on rad 2 to the return on rad 1 to bypass it, this does not look too difficult.
Anybody got any thoughts on my plans and any other tips would be appreciated. Thanks.
