Discuss Blockage at end of waste pipe in the USA area at PlumbersForums.net
I have a blockage running from my shower to sink and out to the waste pipe. I think I need to unscrew this section of the end of pipe to get rid of the blockage, probably hair. I ran a long bendy pipe unblocker from the shower and that didnt work so im assuming the blockage is happening at this bend. Its very hard to unscrew, is there an alternative solution?
thanks guys
[automerge]1595430151[/automerge]
all fixed - hurray
its only the end bit that unscrews you need to use a spanner or a good pair of grips on the raised nut part and unscrew as normal
ignore didn't see the last bit of post
Reply to Blockage at end of waste pipe in the USA area at PlumbersForums.net
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down...
Sonya K
Hello I am looking to install a slimline dishwasher (integrated) into a cupboard in my kitchen. The depth of the dishwasher is 550mm and the...
