Discuss Blending valve for solar thermal/combi in the Plumbing Jobs | The Job-board area at PlumbersForums.net
AllyBongo
Anyone got a link for a decent blending valve for a combi using solar preheat? Intasol's is £295 plus VAT!!
You can get them for less than that mate, seen them for about £250 all in
Reply to Blending valve for solar thermal/combi in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few seconds! Can anyone tell me what is causing this? And how to cure?
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
Can anyone recommend a decent multi meter, preferably under a 100 pounds. It's for checking boiler components so I don't need a top spec one ....just easy to use and reliable. The fluke 115 looks good but its above my budget. My current socket and see one was great but it's developed a fault.
