Discuss baxi platinum combi he losing pressure in the Plumbing Jobs | The Job-board area at PlumbersForums.net
L
Lewis Foster
We've been doing plenty of DIY of late and so a few radiators have been on and off. I'm not sure if we had problems before as we've only just moved in but we seem to be losing pressure and I can't find any obvious leaks.
I tried upping the pressure with a view to locking the system off to see if its the boiler or radiator circuit but didn't get very far. I put the pressure up to 2 bar then locked the two valves off to isolate the radiators but as I did this the pressure dropped by 0.5 bar. Does this signify any problems?
Any help greatly appreciated.
The platinum has a 5yr warranty, 10yrs on new I believe! However if it's out of warranty there's an obvious issue that will be quickly diagnosed/repaired by someone qualified to do so I'd guess :)
Get someone in I say :)
Whilst there on they can chuck some more inhibitor in as it will be watered down.
Is system dropping pressure all the time ? or only when boiler is in use ? how did you drain system to remove radiators ? check outside to see if small safety pipe from boiler is dripping !
Reply to baxi platinum combi he losing pressure in the Plumbing Jobs | The Job-board area at PlumbersForums.net
