Discuss Baxi Platinum Boiler Error E1 33 in the Central Heating Forum area at PlumbersForums.net
Hi Guys,
I have installed a boiler "Baxi Platinum+ 40Kw Combi" on the outer wall in the loft.
It works fine for 1 or 2 days and then it gives E1 33 error randomly. It is connected to the Hive Thermostat too.
I have checked all the common reasons for getting this error but in no way could get the issue resolved.
Any thoughts on what can be causing this intermittently ??
Thanks in advance.
Reply to Baxi Platinum Boiler Error E1 33 in the Central Heating Forum area at PlumbersForums.net
  • Article
A Plumber Who Worked Illegally Gets A Suspended Sentence After Falsely Claiming To Be Gas Safe Registered. A Plumber in Herefordshire was prosecuted after Hereford Trading Standards Team found that he was falsely claiming to be on the Gas Safe Register when he was not, putting members of the...
