Discuss baxi duotec combi 24he boiler, loud high pitched humming, whining noise. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
jonbbb
Hello
I have an 8yo old baxi duotec combi 24he boiler.
When the gas central heating is running, it makes a constant loud high pitched humming/whinning noise.
The noise only quietens for about 5 seconds, each time the boiler reignites to heat the radiator water. Before then returning to the same level.
I am in the room above the boiler, the noise is quite loud and its persistence gives me ringing ears.
[see the link to hear the noise, recorded upstairs. the recording does not capture how loud the note is, only its tone ].
https://drive.google.com/file/d/0B2It1xwGdQ1IX012T1FXYVJLb1E/view?usp=sharing
Further info,
If the central heating is off, but the hot water tap is turned on. The boiler makes the same sound but at a much quieter level.
the diverter valve?* was replaced last week, but the noise is still there.
*Im sure the engineer said he replaced the diverter valve, after I also said that when the hot water tap is turned on for over five minutes, the radiators would fill with warm water.
My questions:
1. What is the noise likely to be coming from in the boiler? [or where has similar noise come from in other related boilers]
2. And when I call out the baxi engineer again, to attempt to identify the noise source. What are the likely parts, where they should first start their fault finding?
Jon
edit:
"The noise only quietens for about 5 seconds, each time the boiler reignites to heat the radiator water. Before then returning to the same level."
should be
"The tone lowers for about 5 seconds, each time the boiler reignites to heat the radiator water. Before then returning to the same level."
And for which you need a gsr to look at it. Let him do his job. It's what you'll be paying him for.
Job 38.11
Reply to baxi duotec combi 24he boiler, loud high pitched humming, whining noise. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
