Discuss Baxi duo tec 24he mk1 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
king of pipes
Subscribed
Anyone know if these are available as a spare ? Can't find one anywhere merchants no use has 2 similar but not right . Cheers kop
Your missing the other half normal stuck in the brass block best to replace the whole thing
correct pair of point nose pliers and pull or replace the whole brass block
Sorted it chaps had to strip out the brass block and knock the broken bit back through the other way , fitted the new one all back together boiler kept overheating in hotwater mode grrrr drained again plate out was blocked not solid but enough to play up luckily I managed to clean it enough with a pressure washer so up and running again . Cheers kop
Had another one today two in a week hmmm was under warranty but sorted it as i fitted in 2016 and was due a service i did get baxi to send me a replacement cartridge though. Kop
Yep they go for fun
No mate didn't fit the 24kw that was 2006 , sentinel x100 stickers on the boiler , 28 erp I fitted adey pro 2 and adey chemicals 2016 this one was clean very little black on the magnet hardly any when I serviced it . Kop
This one was brass though Shaun heat creeping into heating when there was a demand for hot water it's on the drop down flap didn't look anything wrong with it but swapped it and that sorted it
Reply to Baxi duo tec 24he mk1 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Does anyone know where I can get one of these? Toilet is leaking into the bowl. This one pushes in with a half turn but I can't find one anywhere.
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath...
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I...
