Discuss Baxi combo boiler leak from DHW when not used for 5-6 hours in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
N
Nathan DL
Hi
I have a BAXI NETA-TEC COMBI 33 GA boiler and every morning I come down to a small puddle of water underneath the boiler. The gas engineer has replaced two washers in the DHW and a new baxi brass adapter and tightens all connections, still the leak remains.
It does not leak when the hot water is being run it’s only leaks when the boiler is left for a long periods of time without use? any help would be greatly appreciated
Many thanks
Plastic hydro block best replace as it’s probably got a hair line crack
Reply to Baxi combo boiler leak from DHW when not used for 5-6 hours in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
PSxxxxxx
