Discuss Bath mixers needs changing ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
O
Old Account
Hi guys,
just wondering if someone could give me a hint of how to access those 3 tap hole mixer ?
Brand : grohe
problem: whenever you open the rigid tap it lets water by to the shower head which has an attached hose ( right hand side ), left hand side is the ridgid bath filler, middle is mixer.
Obviously, when you open filler or shower head it always leaks down the hole and leaves water stains.
Because the flexible shower head is in and angle so it always leaks down the hole though.
What Would be better changing the whole set or just a cartridge ?
would it help once it's changed so water will not run when you fill the bath ?
Or better of changing the whole set ?
Thanks for your help
kind regards
ron
Don't know if it was cooincidental or not but I clicked on the link and my laptop froze and a few messages popped up saying something about a corrupted file and malware which I couldn't remove
Had to force shut down and restart laptop
Hi
Sorry to hear that johnnyswamp
I always use this website to upload pics ... somehow I can't upload pics from my iPhone directly which is a title annyoing... here I'll try again Ido not k ow if u can see this picture ... I'll delete the previous link.
Remove the handle/knob on the diverter valve and see if the innards can be taken out through the top (if you haven't already)
If that isn't possible, then you have 2 options, bath out to repair/replace taps
Or access from other side of wall (which looks like an external wall so very tricky)
Either way it's a ball ache, but every ball ache has a price :biggrin:
Hello Johnny,
Thank you for your fast help.
I have got a little leave to push up and down / to switch between filling and showering ...
I cannot really take anything out from the top:/
That's what I already thought taking bath out and replacing the 3 hole tap.
You are quite right it's the external wall 1st floor :))) a little bit tricky though.
Best off taking bath out which is also a little of a pain because of the glass panels don't want to break them really :) you also need to take the tiles out without breaking them. Basin needs removing too to get the bathtub out so a little bit of work for this one :)
Thank you very much
Appreciate your help.
Hello Johnny,
Thank you very much
Use an angle grinder to rake out the mortar between half a dozen bricks, replace tap from the outside and brick it back up. Quicker and a LOT less risky than removing bath & sink.
Hi Mas,
Thank you for your advise!
I will definitely consider this solution and will check on Saturday what's outside like.
Kind regards,
Ronny
Reply to Bath mixers needs changing ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I recently had a plumber come over to look at a badly leaking shower head. As best I can recall, he described the problem as a crack in the bridge...
Our master bath shower had two shower heads. One was leaking/dripping so our plumber changed both cartridges since he was already there. That...
DianaCali
Hi, I have a few issues with my bath drainage and leaking. The first issue is that the near corner of the bath by the taps is sloped downwards...
Looking at a particular range (Vernis) of Hansgrohe taps and mixers. A 2 function bath mixer seems readily available but can only find a 1...
