Discuss Automatic way to prevent private supply from freezing up in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
mattwynne
Hi all,
We moved out here to a farm in the Scottish Highlands a couple of years ago, and this is our first cold winter.
We have a private water supply, and some of the supply pipe runs over-ground. Last week in the cold snap, it froze.
We've been generally in the habit of running a cold tap overnight on cold nights, to keep a flow going down the supply pipe. On this occasion nobody noticed how cold it had been during the day until it was too late.
And once it froze, it was a bloody nightmare.
So I was thinking about how I could make something that can automatically "run the tap" when the temperature drops. I have a messy "plant" room where we filter the water before it comes into the house, and I could easily fit something in there. What kind of device would I need to open a valve when the temperature gets low?
Any ideas?!
cheers,
Matt
better to bury the suply pipe between 750 to 1350 mm deep then it wont freeze, your idea is not the answer
Yeh id also be looking at burying it or a new pipe next to it as said above at correct depth.
Bury it.
Lag it with good quality insulation.
Trace heating under the lagging, but it will also need good quality lagging.
Solenoid valve on a timer and frost stat to auto run off the water.
My Son has got a 750mtr run buried down a hillside in Northumberland, that doesn't freeze even with 3 ft of snow on it for a month.
Bury it.
Does he want a gardener.
Best rates for grass cutting :)
Thanks for the thoughts all - I'm definitely planning to put the pipe underground where I can, but it crosses a river at one point and just has to go out in the open air for about a 10m section. I'm obviously going to insulate that section too, but I'd still like a belt and braces approach. There's no harm in keeping the water running - it's free!
Overall the run of pipe that stands still when the taps in the house are off is about 80m long.
Thanks for the links to Heat Trace - that looks perfect if I can afford it. I'm gonna investigate.
When you say it crosses or runs by a river is the water flowing ?
I have seen a farmers supply running in a fast flowing stream that never froze so neither did the pipe as it was submerged !
The only reason it was never buried was due to all the ground around being solid rock !
It crosses a river. I can't submerge the pipe as the river goes from trickling stream to raging torrent depending on the weather, so it would always be at risk of getting ripped out, I think. I dunno - maybe I'm wrong and I could spend some time in summer pulling rocks out and trying to bury it under the river bed.
Yeah it crosses the burn, and I'm scared to try and bury it in the river bed as it goes absolutely mental when it's in spate.
Sure.
Wont take me long :)
Hi all,
This is crazy, think of those oxfam ads where kids travel miles for drinking water & your going to bed at night with the tap running!!!
Reply to Automatic way to prevent private supply from freezing up in the Plumbing Jobs | The Job-board area at PlumbersForums.net
