Discuss Automatic air vent in the Plumbing Jobs | The Job-board area at PlumbersForums.net
L
lenny
Should the cap on and AAV be left loose, tightened or completely taken off when a system has been fully purged?
Len:confused:
left loose also somewhere for the steam to go if the pump fails(not all boilers have pump pressure switches)
What a load of rubbish, thats partly what pressure reliefs are for.
We don't use automatic air vents anymore as they always leak after a few years.
Once the system has been filled and vented you shouldn't need to leave it open.
Reply to Automatic air vent in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Article
A Plumber Who Worked Illegally Gets A Suspended Sentence After Falsely Claiming To Be Gas Safe Registered. A Plumber in Herefordshire was...
