Discuss Auto air vent for shower pump installation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
dhes
I'm about to install a monsoon universal 2 bar pump in the attic (there is no where suitable next to the hot water cylinder). I am going to take the supply out of the hot water storage cylinder using a techflange with 22mm copper pipe, put in a 350mm downward loop and then take the supply directly up into the attic. When the supply gets into the attic I was going to fit a equal T with the supply to the pump branching off and a auto vent at the top. Does this sound OK or would I be better fitting a manual vent. If this is OK could any one recomend a good quality auto/manual vent.
It Will work fine without a flange. Air free delivery can be achieved by simply seeing downwards from the horizontal distribution from cylinder. Look at aqualisa website go to shower manuals and look at diagrams of connections for pumped supply.....you Will see what i suggest is actually the most preferred method :)
Should read 'teeing' and not seeing!:mad:
Reply to Auto air vent for shower pump installation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I'm in my new build 2 years and the shower pump has died. I have an air to water unit downstairs is in the utility which I've been told is...
Hello, my Mothers heating failed in the recent UK cold snap. I found the pump was stuck. I have a question about pump orientation. The...
Hello, I am renovating a small bathroom in an apartment on the 5th floor. Heating is electric, no gas or oil. I have four (related) questions...
Hi. I'm currently estimating on installing a new shower pump to feed an existing bath/shower diverter. Hot side: fit flange and spherical valve...
5K
Hi, Found some great answers here but first time posting, go easy on me please šŸ˜‹. Looking to fit a salamander rp50tu shower pump to a gravity...
2K
