Discuss Ascending spray bidet in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi All, Just installed a supply for an ascending spray bidet (separate feed from cold water storage tank with in line instantaneous dedicated heater) and now cannot find a supplier for the intended back to wall bidet. Does anyone know of a supplier?
Thanks for your suggestions but I'm looking for a freestanding traditional type bidet. Conventional back to wall toilet is already fitted.
I know they are still made because a colleague has seen one in Saudi Arabia but googling in the UK just brings up smart toilets plus lots of references to water regs for ascending sprays. I'm actually puzzled as to how these new smart toilets avoid contravening the water regs. I'm sure they are not fed from a separate feed tank to provide the requisite back flow check.
Reply to Ascending spray bidet in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
