Discuss Ariston water heater pressure in the USA area at PlumbersForums.net
I have moved plumbing pipes for Ariston lux water heater
As far as I can tell have moved and installed all pipe work correctly
Fitted expansion vessel and pressure reducing valve
Not yet switched on for warm water , Just testing for leaks etc using cold
Without switching on …so when I go to run water through hot tap the pressure falls off after a few seconds . When I then run the cold tap there is pressure again in the hot.
This didn’t happen before I moved it
I’ve come off mains which then goes into sink and then goes into pipe work for heater
I’ve tried various ways but pressure still falls off
Reply to Ariston water heater pressure in the USA area at PlumbersForums.net
