Discuss Ariston MircoCombi 23 MFFI hot water query in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hi all
I have the above system, I know (old and not the best) however it has served me well, considering it was already fitted in the property when I moved in.
Earlier this year I had the main and secondary heat exchangers replaced by British Gas (long story - they didn’t need changing but as they were BG they insisted, however back then the problem still persisted so I didn’t get charged for it; it was a faulty expansion vessel in the end!)
Anyhow I currently have a problem where the hot water downstairs or upstairs is tepid even when the dial is cranked up to max.
Heating works fine.
I have narrowed it down to the temperature probe, however I have a query.
Do I need to drain the system down to remove it as I can see it is fitted near the secondary exchanger? This is so I have inhibiter at hand (added 2 bottles of Fernox F1 in October so will be gutted if I have to)
Also, does the lead on it come off easily? Do I just pull it off or is there a technique to it?
That’s it really.
Would appreciate the guidance as the lack of “hot” water is making for a quick bath at the moment
Do you know of one in the Birmingham area that’s willing to do it? I have the replacement probe. Also I have a number for a local guy but he’s been avoiding my calls all week!
It could be a number of things but seriously stop guessing and throwing parts at the problem and get another gas engineer. To be honest I’m guessing the conversation went “I need you to fit a temp probe to my boiler, it’s ok I’ll supply the part, I’m sure that’s the problem”?? Most engineers like to diagnose faults and supply their own parts that could be why he’s ignoring you
Reply to Ariston MircoCombi 23 MFFI hot water query in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, I have an OSO Direct 210 hit water cylinder installed in my home, with 2 switches (on/off; and boost). The boiler is for hot water only (rads are electric). In the 5 years that I’ve lived at this property, I’ve never once turned the boiler off; however, with soaring energy prices, I’m...
So a strange conundrum regarding water temp if anyone can help resolve, would be much appreciated. Ive tried to give as much info as possible to give a full picture but let me know if ive missed anything. I have a Baxi Avanta 25h heat only boiler. Works fine. Unvented 300ltr megaflow. Stated...
G
I've just bought a 3-floor house with a gas boiler on the ground floor and hot water tank on the middle floor. When I switch on the hot water at the timer panel, it works but it also heats up all the radiators above ground floor. I have to close them individually to stop this. The rads aren't...
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new well maintained Worcester combi boiler. We weren’t convinced the heating was working right and then got hit with a £610 energy bill for the first 6...
MartinPod81
M
Good Afternoon all, I am hopeful someone may be able to offer some guidance on the following. In the home we have a gas boiler (serviced annually, October time) providing hot water to the CH system which is split into 3 zones (Honeywell 2-way valves) and it also heats the HW tank (Tribune...
