Discuss Are all MDPE pipe makes the same size in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just got some 25mm floplast fittings and inserts (black) and some 25mm MDPE blue pipe. The problem is the floplast inserts only go in about 10mm into the pipe and are too tight to go further. The MDPE pipe is waven.
I tried white inserts polypipe and they fitted ok. I know you cant mix speedfit pipe with hep fittings etc.. Is there different MDPE pipe for different fitting as in above ground?
Any suggestions appreciated​
Never saw black inserts just clear/White
Might need to file them down a bit
Never used a screwfix insert but MDPE is all the same size. Just hammer it in and shove the fitting on.
I think it would kill the moment if you ran out to the van for a tin of silicon spray:uhoh2::smile:
i have used sun bathing oil in the past :rolleyes4: :1eye: did the job :) will not be running to the van in that moment no wway
Reply to Are all MDPE pipe makes the same size in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
Hello I am looking to install a slimline dishwasher (integrated) into a cupboard in my kitchen. The depth of the dishwasher is 550mm and the...
