Discuss Are 15mm inlet pipes okay for this? in the USA area at PlumbersForums.net
Hi all. I'd appreciate if anyone can tell me whether this shower will work with the two 15mm pipes (150mm centres) I have coming out of my wall? Thanks.
According to the installation instructions:
the inlets are '15mm compression at 153mm centres', which is the same size as your existing pipes but with a 3mm difference on the centres. So, it's not going to be a plug-and-play installation, assuming you measured '150mm' accurately and there is no 'play' on the existing pipes.
Thanks. This is boiler and cylinder, hoping it's okay?
Reply to Are 15mm inlet pipes okay for this? in the USA area at PlumbersForums.net
