Discuss Anyone know where I can get trim like this? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
armyash
Subscribed
Another request for info if that's OK....
Looking for trim like the one in the picture. Nothing available in the local tiling shops. Off to a plastics place in the morning who usually have a good selection but failing that does anyone know where I might find it. 12mm needed for 1 edge. Other edge can be minimal.
Thanks.
Ash, most of us just use standard tile trim for that application?
Get some of the flat L- shaped stuff as it’s a lot easier to make that look neat compared to the quadrant type.
Depending on the tile thickness as you can get 6,8,9,10,12,13......mm in one direction and thickness of the metal the other way(usually 1,2 mm) - available everywhere in white/cream/chrome/brushed etc ; special order for odd colours.
Reply to Anyone know where I can get trim like this? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
The isolation valve connected directly to our toilet fill valve has started to leak (I assume the washer has deteriorated). I'd like to get a...
This unit is located in France where they use diesel not kerosene. The feed from the underground tank is not getting through to the boiler. The...
Hello there, Relatively recently we had a new en-suite fitted (complete rip out of the old fittings, and old wall tiles and floor carpet). This...
Hi, I have removed a seized bath plug from my bath, but would like any advice about how to go about finding a replacement. Please see attached...
Got what is probably a simple issue if you know how.... getting as far as the ceramic cartridges so I can get them out, measure, and hope they are...
1K
