Currently reading:
Another mysterious plumbing noise question
Discuss Another mysterious plumbing noise question in the USA Plumbers Advice area at PlumbersForums.net
Recently, my ground floor toilet has been making a periodic noise that sounds a lot like a pump is rapidly pumping water into the tank in little squirts. It is always the same length of time, about 15 seconds.
The toilet is on the ground floor near the line in pipes and I can hear the noise there as well.
It's not a hammer sound or anything remotely moaning or hissing. Literally a squirt, squirt, squirt, squirt about 2 a second, very precise. Like a pump somewhere outside the house system is running on and off at irregular times.
Any thoughts? Should I drain the house or something else as a test?
Sounds like the fill valve is at fault I would replace the fill
Reply to Another mysterious plumbing noise question in the USA Plumbers Advice area at PlumbersForums.net
