Discuss Alpha intec 28x fault code e96 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
kevin
Hi guys,
Could anyone shine a light on this fault, not listed in the MIs?
Many thanks
Kev
i think its somthing to do with solar kevin
Now that’s interesting to know it’s a weird one lol sitting in my digs and you get a phone call before your about to put the light out now am looking through all sorts
Hi guys,
Had a chat with alpha on this error code, it seems that this error will show up if the boiler haven't been serviced full strip and service should do the trick will post outcome.
Cheers
Kev
Never seen that one before
How do you reset the service reminder?
Hi Shaun,
Basically the alpha tech help said right away the boilers never been serviced because of this fault code on investigating on the mi's you need to do a strip and clean of the burner check flue seals etc. from what I have found out it's like the isar if the sumps clogged then it won't go.
Reply to Alpha intec 28x fault code e96 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello All I have an ecotec 630 with Sensohome controls. Should the fault codes shown in the boiler also be reflected in Sensohome control? All...
Hello Wondering if anyone can offer any clues please // Potterton Promax 18 // Had an E1 error code, repressurised via with filling loop //...
Hi All, Have a peculiar problem with my Gloworm Flexicom 30cx combi boiler, the main heat exchanger is getting red hot and fault coding on...
Hi all I have a britony combi se 80 with fault 40 60 80 had british gas out to repair under homecare cover but they can't seem to repair it. They...
Hi Called out to a Alpha Intec 2 with e43 code, reset boiler it fine for a few days then comes back .It had a new gas valve fitted a year ago by...
5K
