Discuss Alpha eco2 ..... any good? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sharp Point
evening guys n gals,
Never ever fitted an alpha of any sort. Is this boiler any good? My mates only got a budget of £700 for a boiler flue and clock. I providing pipe n fittings.
Yeah, fitted a few Evokes, pretty decent for the money.....
I’m swinging towards this boiler, because of the 7 year warranty.
Lol, let’s see if they’re still playing ball in 6 years time.
Get an extra year with their cyclone filter, doesn't look great but heh ....
Vaillant eco fit are cheap really for what you get. Bit over buget but not much
I have fitted 3 this year good as any £700 boiler with a decent warranty
Reply to Alpha eco2 ..... any good? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, my Mothers heating failed in the recent UK cold snap. I found the pump was stuck. I have a question about pump orientation. The existing pump flows downwards. The manual for the proposed replacement recommends that it should pump upwards. This would involve rearranging the flow &...
Hi, I need some urgent advice. I've Just come home after going out for evening, to discover hallway floor and kitchen floor covered in water. On further inspection I discovered that water was coming from boiler cupboard. On looking in boiler cupboard I found boiler has started leaking water...
Morning, I have a job later this week with the above , Viessmann Vitodens System boiler. It has a 4 pipe setup with internal diverter and at present there is a wireless thermostat/programmer controller in the hallway. Customer wants a Honeywell Evohome System and I just wondered if I can wire...
I've got a non condensing Glowworm Ultimate with gravity tank and hot Water tank in a 4 bed house. 11 radiators 1 double 1400mm length 1 P+ 1400mm length 2 P+ 400mm length 7 singles 400mm 1 mains shower average water pressure Any recommendations on combi boiler and KW? Boiler budget...
Hi, i've got a job with a Vaillant Ecotec 630 system boiler, and i don't know the full history but the house has definitely been extended significantly since the boiler was installed. There's now 21 radiators/towel rails. It's getting to temperature, but even after balancing, it's not heating...
