Discuss Airlock/low pressure power shower problem. in the DIY Plumbing Forum area at PlumbersForums.net
Hi there,
Our power shower has had very poor pressure for a long time, so I decided to bleed any air out of the system (which there was a lot). it works great to start with but gradudually the pressure falls and there is more air in the hot water system. I have done this about 6 times now, so I believe that air must be entering the system somehow.
The pump is an Techflow QT80.
I believe that the outside Right hand side pipe is the hot in which goes to the top of the tank/inside RHS pipe is the hot out.
The outside Left hand side pipe is the cold in/inside LHS pipe is cold out. (Images below).
If anyone can suggest anything to try, I'd ve very grateful.
Thanks in advance.
Martin.
Reply to Airlock/low pressure power shower problem. in the DIY Plumbing Forum area at PlumbersForums.net
