Discuss Airlock in Evinox (RC15) boiler cylinder coil - How can I release it pls? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have an Evinox Heat Meter Mod RC15 Boiler. I had a cold spot on a radiator and bled it.
The boiler pressure dropped to 0.5bar. A red warning light came on on the boiler and on the wall mounted 'viewsmart' controller. I refilled the boiler back to 1.5bar. The warning light on the controller went out but not the one on the boiler.
I made no other changes but now neither the heating or hot water are working.
There is a steady green light on for the (Wilo Pulse-width modulation (PWM)) pump (i.e. its working fine). There are no noises or gurgles. The cold water runs fine.
I also have an immersion tank. If I switch the immersion on then the hot water and heating work fine. Hence I think the problem is boiler related.
I spoke with Evinox and sent them the system read-out from the viewsmart controller. They said the readings were fine. And they think the problem is an 'airlock in the coil in the cylinder'.
I have re-bled all the radiators and towel rails - and had no success with that.
I cannot see any other vents on the boiler...so can see no way to vent the airlock out of the system.
I have read the following two comments advising to:
- "crack open the nut on the return until water flows. careful not to flood the house"
- ...and " prevent the boiler firing and then start and stop the pump a few times until it cleared the air. much less messy."
I am not sure if the above comments are the way to proceed and if so I am not sure how to do either of them.
So I'd appreciate any advice on the above ideas or any new ideas to help me release the airlock please?
Thank You, Mo
Ps. happy to send photos or skype if anyone has the time please
Have you reset the boiler eg normally via s reset button or turning it off and on again ?
Thanks for your reply. I could not see a reset button on the boiler (and Evinox confirmed there is not one).
But I have turned it of at the wall for 60 secs and then back on again. I can hear the boiler firing up, see the light for the pump flashing and then turning to steady green....but the boiler's red warning light comes back on and the problem with no heating and no hot water does not fix itself.
Best to get someone out who works on them you might have a service contract on it
Reply to Airlock in Evinox (RC15) boiler cylinder coil - How can I release it pls? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
