Discuss air to air heat pump heating system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Looking for advice, my son is moving to a house that has no gas but has an air to air heat pump heating system, the question is do you still need to balance the radiators?
Any advice and links.
Thank you.
Tell us more about the system. An 'air to air' system blasts warm (if you're lucky) air out of vents and may well not have any radiators just a lot of ducts around the place.
As above air to water will have radiators or possibly underfloor heating air to air is more like air conditioning , in answer to your question the system will need balancing to achieve the temperature drop across the system add exchange the heat into the room . Kop
Reply to air to air heat pump heating system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Sticky
