Discuss Air or not in the USA area at PlumbersForums.net
Riley
Super Moderator
S. Mod
Subscribed
Just done a boiler swap and this is killing me. Sealed system was a greenstar ri have put in Glowworm R so no diffference. New pump. Can get all rads hot individually but not all together so no blockage. Out of ideas here any thoughts. Boiler cycling on n off but heat going nowhere else
Piped correctly?
Gone over it and over it. Right pipe on Worcester was return nothing else to get wrong really
Drain off on boiler ?
if so shut the pump and drain a bit out of it
No drain off but AAV above. I’m 99.9% sure pump is right way round as I goes down and under and into centre of three port
A few more thoughts.....maybe stick a pressure gauge in one rad's blank vent to ensure static head is same as filling pressure of 1.5 bar or whatever, allowing for difference in pressure gauge elevations. If OK increase the filling pressure to 2.5 bar temporarily which might collapse/shift any entrained air.
It does point to a head/circulation problem for whatever reason as one rad at the time only circulating, suggest re installing the UPS3 and beg/borrow a energy monitor, put the pump to full speed 3 and measure the power.
27W = 0 circulation, 36W = 0.3 m3/hr, 5 LPM (one rad maybe circulation). 43W = 0.6m3/hr, 10 LPM (minimum, "normal" expected) and 60W = or > 1.1 m3/hr, 18.33 LPM.
That sucks, well done finding it.
I did a boiler the other week and didn't realise until commissioning that all 5 rads in extension had massive highspots (when I saw the pipes behind the rads I assumed it ran down the wall, not up from the floor and back down to tails!), combined with vented system it was a massive PITA!
It can happen not infrequently in systems that have pumped zones which have a (poppet type) NRV on the pump(s) discharge to stop gravity circulation.
Reply to Air or not in the USA area at PlumbersForums.net
PSxxxxxx
